Lyndall's avatar
Lyndall
Follower
Jun 16, 2019
MR2100
I have got a MR2100 and the modem keeps freezing dropping out and the only way to fix it is to open the back take the battery out and restart it. I have tried resetting it and then it started coming...
  • ArodiD's avatar
    ArodiD
    Jul 12, 2019
    Hi Lyndall  and Brucewh2 ,
    Can you please provide the FW versions of your units?  The latest FW is 10.13.05.00 so I would recommend upgrading to the latest firmware if you have not already.
    Arodi
    Community Team
