att340u
Jul 24, 2024Initiate
MR5100 won't factory reset
My hotspot is working, but I can't change a darn thing as I have lost my admin login to the web interface. So, trying to perform a factory reset. Using the on-device interface/LCD, I goto Sett...
Blanca_O
Jul 30, 2024NETGEAR Employee Retired
Hi att340u,
Please follow the steps below to power off or reset the device:
1. Hold down the Power button for 5 seconds.
The Power Off/Reset menu appears and you are prompted to power off or reset the
device.
2. Tap Power Off to power off the device, or choose reset to reset the device.
You may also check this link to look up Mobile Router's default Web UI address and Admin password: https://kb.netgear.com/23379/
Blanca
Community Team
