Shauns65
May 21, 2021Aspirant
MR5200 poor 5g speeds EE
Somebody please help, i've come from a Nighthawk M2 to an M5 and the 5g speeds i'm getting from it are dreadful, I took the sim out of it and placed it in my Iphone 12 & was getting 300 Mbps download...
W1lliam
May 22, 2021Virtuoso
MR5200 is not having all available bands opened in “Auto” (no longer named “All”), you might need to pick up “LTE and NR5G” to try with full supported bands.
TeeJay74
Network can handle certain amount of CA combos, much less than terminal side. Band region "All" includes 3G which is obsolete technology, so to get best CA combo's it requires "LTE and NR5G". Then it's up to network side what happens next, does network force terminal to use only CA combo's which are supported on the network side(I think this is preferred method), or does it prefer terminal side CA combo list.
