blondieblue227
Aug 05, 2015Aspirant
Re: NetFlix not working on AppleTV
i have a zing hotspot thru sprint. ever since i started using it, netflix won't play on appleTV i tried using another hotspot thru nTelos and i have no problem at all playing netflix on appleTV. i...
DarrenM
Aug 11, 2015Sr. NETGEAR Moderator
Hello Blondieblue
Have you tried doing port forwarding on your zing something could be blocking a port the apple tv needs to work here is a link to ports that the apple tv uses. let me know if this works
https://support.apple.com/en-us/HT201733
DarrenM
blondieblue227
Aug 13, 2015Aspirant
when i used netgear chat i asked them to show me how to forward a port. i don't think that was done, all they had me do is reset a DNS setting which did not work.
i'm willing to port forward if somebody will walk me through it.
at this point, sprint is blaming netflix AND netflix is blaming sprint.
they are both going to loose me as a customer.
- DarrenMAug 13, 2015Sr. NETGEAR Moderator
Ok what you need to do is log into your zing then click Settings-Router-Port Forwarding Now you will want to click enable.
Ok now with port Forwarding you will want to enter the ports you want to forward. First off you will need to know the ip address of the apple tv that is connected you should be able to find this in the devices tab on the left. once you get that you want to fill in apple tv in the first field then its Ip address in the second one (dont use 192.168.1.1 I used that as a example) and then the last one is the port you want to open these are listed on that apple article I linked before plus it will tell you If its TCP or UDP after that hit submit and repeat the process for every port you need opened.
Let me know if you have any more questions on this Ill do my best to try and help walk you threw this.
DarrenM
- blondieblue227Sep 03, 2015Aspirant
that did not work.
are any other ports i should open?
yesterday i took the hotspot into a sprint store. they said netflix had blocked the signal to the hotspot. i don’t know why they would do that because i pay $120 for 30GB per month.
- DarrenMSep 14, 2015Sr. NETGEAR Moderator
Hello Blondieblue
I dont have any other ports that could be opened I find it odd that netflix works on all your devices but the apple tv. Has there been any updates for the apple Tv or to the youtube app on the device? also you may want to tell the apple tv to forget the wireless network and try to connect to it again then try netflix.
DarrenM
