Q8cracker
Jul 29, 2017Guide
Netgear M1 reboot issue Resolved!
Netgear M1 reboot issue Resolved! i found the real problem that relates to router reboot "randomly reboot" was from your country network band , Tut: 1- go to admin page 2- sign in 3- go to set...
Byrddd
Dec 08, 2017Tutor
Hey, have you happended to found out what was wrong with your device? Mine started doing the same thing any large download causes reboot
Teewee4134
Dec 08, 2017Guide
I still waiting and hoping there would be a new update.
My issue not yet solved
- ByrdddDec 08, 2017TutorThanks for the reply! It’s crazy they haven’t fixed the problem yet..have you tried just using 1 WiFi instead of dual band?
- Teewee4134Dec 08, 2017GuideYes, I have but same issue
