Q8cracker
Jul 29, 2017Guide
Netgear M1 reboot issue Resolved!
Netgear M1 reboot issue Resolved! i found the real problem that relates to router reboot "randomly reboot" was from your country network band , Tut: 1- go to admin page 2- sign in 3- go to set...
aawada
Jul 02, 2018Aspirant
Heavy usage is causing rebooting both with and without battery included.
winger13
Jul 02, 2018Guide
If the router reboots with just the battery in, I believe you have a different issue than the others have reported where the solution is to utilize a Quick Charge 2.0 or 3.0 certified charger.
Without the battery, can you narrow down whether heavy downloads causes reboots only when the router is on specific band(s) - see the diagnostic screen for this info. For example, in my case band 30 and I believe band 2 (tryng to remember from memory) always reboots when the device is processing heavy internet activity.
