YoungJo
Feb 20, 2025Aspirant
Netgear M7 pro unable to connect 5G in S.KOREA
Model: M7 pro (#MR7400) Firmware Version: NTGX75_10.03.22.01 Software Version: MR7400-1A1NAS_02.11 Hardware Version: 1.0 PRI Version: 02.11 My device is an AT&T model but is carrier unlocked. ...
YoungJo
I'm not entirely sure if N78 is not working, but even with manual carrier selection, my device only recognizes 4G (while Korean phones show very strong 5G signals in this area) and does not detect 5G at all. After searching various local forums, I found that some overseas carrier-locked devices may have a sort of region lock, which makes me suspect that N78 might be restricted. So, I'm asking if there is a way to force N78 activation or remove the allow list(region restrictions) through firmware modification or debugging.
rcpax JohnPeng
rcpax JohnPeng
JohnPeng
Feb 20, 2025NETGEAR Expert
ATT M7 doesn't support 5G SA so far. That may be the reason you couldn't connect 5G right now. Please wait for the coming maintenance release with 5G SA supported.
