saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
TamiAsmi
Mar 26, 2023Initiate
Dear Blanca,
I just got my Netgear m6110 and unfortunately I faced 2 problems
1) regarding the battery consumption.
2) the 5g signal is difficult to maintain.
Is there any chance that you will update the software to resolve those issues ? because I have a chance till the end of the week to return the router and buy another type.
Hadeiazmi
Mar 26, 2023Star
I went to the stc maintenance center, which is more than an hour away from my house, just for an update! Unfortunately, I got an update and it did not solve the battery and heat problems, and the wifi 160mhz option was also canceled? Why haven't the problems been solved? Why was the 160MHz option canceled?
New Firmware Version
NTGX65_10.04.23.01
NTGX65_10.04.23.01
