Adonahi's avatar
Adonahi
NETGEAR Nighthawk M1 Temperature Operation
Hi there. Anyone can confirm the recommended ambient operation temperature for the MR1100 – Nighthawk M1 Mobile Router...? for example the device can operate between -10°C to 40°C...?   Thanks
  • JSchnee21's avatar
    JSchnee21
    Sep 16, 2018
    The manual says:
    0C to +35C operating
    -10C to +60C storage
    Table 4, page 91
    https://www.netgear.com/images/InstallationGuide/mobile/MR1100ATT/MR1100ATT-USERS-MANUAL.pdf
    Why inside of a cold room / walk-in fridge?  Reception won't be very good (Cellular nor wifi).  Better to mount on outside of Cold room, use QC-3 enabled power supply (anker) and run Ethernet to your devices.  OR. if you have wifi / Ethernet devices inside the cold room, be sure to wire and mount external Cellular antennas outside the coldroom
