Barca95
Feb 17, 2021Initiate
Netgear Nighthawk M5 MR5200 WAN issue
Hi, I have a Netgear Nighthawk M5 MR5200 (ip address 192.168.1.1) that is working with the IP passthrough and it is connected to the WAN port of an Asus AX11000 (ip address 192.168.2.1). I can acces...
RonGonz
Dec 23, 2021Star
rylos wrote:And here you are right. And here there is something to be fixed by netgear. Mr5200 with dchp disabled and ip passtrough enable will first release a local IP address, and after 10-60 seconds, will release the external public address.
Currently I can see this thing realtime on my OpenWRT router at home, wan is temporarly assigned 192.168.x.5 and after 10-60 seconds the real external IP is leased and passed, so wan change address accordingly. This will work for 2-3-4 days, than wan loses the address and baaam, mr5200 is connected to lte but not serving connection.
Very buggy.
You are right, so there are two distinct problems that may or may not be related:
- the first is the rfc1918 ip address assignment: I think what might be happening is that on Reboot the local device dhcp service starts and assigns an rfc1918 ip, then later in the startup process the dhcp server is killed and that allows the remote dhcp server to assign the address.
- the second is that when the unit does disconnect or loses the wan address, apparently it can't recover gracefully and pass thru a new dhcp lease. Very strange behavior indeed.
Kindest Regards
P.S. The next thing NetGear needs to fix is this terrible forum software, the editor is absolutely horrendous!
hughhalf
Dec 25, 2021Aspirant
Appreciate all the answers and insights here folks, truly. Gives me a few things to check into over the Christmas break.
All the very best to all for the holidays!
Cheers,
Hugh
