JSchnee21
Sep 23, 2018Virtuoso
New Firmware -- Overtemp warning
Saw a new message and icon on my mr1100 since updating to the most recent AT&T firmware a week or so ago.
While it's good that the mr1100 now tells you why it is not charging -- due to battery/devi...
shastss
Aug 22, 2019Aspirant
I also just purchase my Nighthawk MR1100 from Amazon and started using it on 8-10-2019. I also am getting the same results as others in this thread. Netgear we need your help. Please dont ignore this thread. This is a serious problem for people who require the use of the this device in our day to day jobs. You got my money because I needed the long battery life and the performance is nice.
JSchnee21
Aug 22, 2019Virtuoso
Hi shastss ,
How / where are you using the MR1100? While my unit displays a similar temperature "issue" in my day to day usage of the device, it's not normally a show stopper.
Generally I charge up overnight (sometimes it has to cool off first) in the house where it is ~72F. Then I use the device all day the next day in a variety of climates -- including hot cars (though not direct sun).
Rinse and repeat.
I do use a Anker QC2/QC3 charger and a high quality Anker USB-C cable. Sometimes my unit does display the temp warning when I first plug it into charge. But once it cools off on its own in 15-60min it starts charging automatically.
More often than the temp issue, I have problems with the softpower button turning on/off. Or the unit hangs when starting up or shutting down (once it's up an running it's usually okay). I also have issues sometimes during the USB-C charging "hand shake".
At which point I just pop the back cover off (which is now very loose) and take the battery out, wait ~10sec or so, pop it back in and restart. Problem solved.
At this point the MR1100 is probably a lame duck. Hopefully, Netgear/AT&T are fixing many of these issues for the MR2100 which should be released (fingers crossed) in Q4 or Q1.
-Jonathan
- BigBroIsWatchinAug 22, 2019Tutor
my battery has always gotten hot (or so it thinks at 41*) and shuts itself down. has done that since day one and can not even feel the difference in the battery or the device and mine only goes in if i need to move it for something as i keep mine hardwired. it takes about 2 minutes until it will shut itself off from charging. they do not care they already have your money. i am afraid you will not find NETGEAR any help at all friends. you would have better luck catching a little leprchaun and taking his gold than you ever will of a NETGEAR employee helping anyone out. what else would you expect from a company that sells a product where the functions do not intentionally work as YOU would like and expect them too but rather the way their partner that pays them wants instead? itI'm guessing they think it generates more money and return customers for them when they don't fix it. look for them to go into the internet business soon. on a side note i did manage to enable a port forwarding rule ...lol
- shastssAug 23, 2019Aspirant
Jonathan,
I have a tethered Aruba RAP-109 device to the eth port for work when possible.
When not possible, I use Global Protect (vpn) through the Nighthawk, hence the need for solid battery operation.
So I used this highly technical solution to get a full charge. I put the battery in the fridge for a few minutes, then plugged it in and watched the mobile app temps in advanced info. As the temp climbed from 30C to 40C, I took a bag of frozen veggies out of the freezer, put the unit on a paper towel on the bag of frozen veggies. Watch the temp drop back down to 33C and it seemed to break past the point where it gave the Battery Mode Error, and charged fully. Once charged fully I put the veggies back in the freezer for next time. So far it has not dropped below 96% charge and is hovering at 39C.
- JSchnee21Aug 23, 2019Virtuoso
Nice! Yes, there are others that use the freezer/ice bag approach as well.
You can also run the MR1100 without the battery in a variety of ways:
1) QC2/3 car charger
2) QC2/3 portable battery
-Jonathan
- DingalThorpeOct 01, 2019Aspirant
FWIW,
I was looking for information about this not-ever-charging-the-battery-because-stupid-somehow MR1100 problem. It is rewarding to see that it affects others.
I consider this problem solved for me. Thanks!
Some data points that I've collected:
- Using the factory-supplied adapter, charging almost never happens, although it has charged the battery approximately twice in the four months I've had it, for whatever reason it decided to do this. Ambient temperature doesn't matter: The battery is too hot, it normally says. (Although one time, it told me that it was reducing charging current to prolong the life of the battery, which would be lovely, but it still didn't do me the courtesy of charging it.)
- The modem works fine without a battery and the factory-supplied Netgear US 120VAC adapter, which doesn't support any iteration of QuickCharge. I have used it this way continuously, with constant 24/7 data transfer (easily averaging over 10 megabits over the duration), for months at a time. It is stable in this configuration, for me.
- According to the indicators on my QC II battery pack, QuickCharge is indeed being utilized if it is available. I did not measure the voltage on the wire to see if it was 9v or 12v, or the current, though it would have been interesting to have done so.
- When using QC II, the status screen in the modem declares that the battery is "Quick Charging" and does actually charge it.
- Using an old 2-port Anker USB travel adapter that predates all iterations of QC, the battery does indeed charge. It has increased from 3% to 12% over the past few hours (during which time it has been both powered on and actively transferring data), which is adequate for my purposes.
From this, I can deduce that QC isn't needed (but it's probably nice to have), that a somewhat-unremarkable, high-quality aftermarket power supply from Anker charges the battery without overtemperature alarms, that the temperature alert is a bug as-implemented, and that the included US 120VAC Netgear adapter is completely unsuitable for use with the device that it came with.
