Glocknerblick
Mar 29, 2018Follower
Nighthawk M1 - selection of LTE Frequency/Band
Hello there, is there any way to select the LTE Band/Frequency the router should log on to? This would really help to avoid switching from a "good" cell to a bad one. With Huawei Routers I can do th...
JasonN
Apr 12, 2018NETGEAR Employee Retired
Hi Everyone,
As of now, Selecting a band for the M1 is not possible yet. The feature has been forwarded to my internal team and they are reviewing for consideration. :]
- Jason N
eggYsan
Jul 17, 2018Initiate
I feel ripped off I paid a lot of money for this mobile hotspot for it to crash every movie everything I stream every download every time because it keeps jumping to band 30 which gets one bar And no data! Fix it!
- carleast01Jul 28, 2018Tutor
It's crazy that they don't allow you to choose bands. Where are we with this request. What's really annoying is that this thing is advertised as the fastest thing known to man yet it only achieves 25% of the speed that my phone does! If I reset it then it will sometimes get the same as my phone but it's only a matter of time before it drops back. My guess is that it's to do with the band. I'm stuck in B3.
