Srennie837
Jan 24, 2018Tutor
Nighthawk m1 4g+ only
Hi, My Nighthawk M1 (EE UK, not US) is currently connecting to a mast with 5 bars of signal on 4g, and gets 10mb/s speeds. There is an other local mast with 3 bars of signal on 4g+, and can get u...
englishl1989
Jul 09, 2019Aspirant
How did you work out what AT commands to enter (in case I wanted to add any other bands in the future?)
Considering buying one of these - would you recommend it for performance? What sort of speeds are you getting with it locked to a band?
MrBooMY
Jul 12, 2019Aspirant
https://mt-tech.fi/en/enable-manual-band-selection-on-netgear-mr1100/
That's where he got it from and it works. Also if the value is all zeros you can do a single 0. Also if the value is 0080000, you can do 0,80000 without the other zeros.
