mufngruf
Aug 14, 2019Aspirant
nighthawk M1 battery indicator
simple question - I have studied the booklet, searched the website and googled 'til my finger bled.. but I can't find the answer. My Nighthawk thingy has a circular battery light - at least that's w...
JSchnee21
Aug 14, 2019Virtuoso
Photo please?
- mufngrufAug 15, 2019Aspirant
here ya go
- OxygeneAug 15, 2019Apprentice
Set a limit of your data like 10GB or whatever and you will see how much you have used on the right, yellow means how much charge you have left...
- JSchnee21Aug 15, 2019Virtuoso
Oxygene is correct. The left hand side is the battery level of charge. In the picture you're at approximately 55-60% charged. Top is full, bottom is empty.
Same thing on the right, but for data.
