schoollane
Mar 14, 2021Initiate
Nighthawk M1 does not port forward
Hi All, Having problems with my router and port forwarding. the router has been factory reset and default settings are used. port rules have been setup in port forwarding after a reboot google my...
michaelkenward
Jul 06, 2025Guru - Experienced User
You have joined in on an existing conversation, started and last updated four years ago, that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
Just another user with time on their hands.
