Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
UK-based
Feb 07, 2018Luminary
What's the full version number you're currently on? It's interesting to compare versions in different countries for different carriers.
PerthPhil
Feb 07, 2018Tutor
NTG9X50C_10.16.04.04 and saying it checked for a firmware update 6/2/18 1:14pm
- UK-basedFeb 07, 2018Luminary
PerthPhil- here's what one of the Netgear moderators said about the version you've got: When-are-we-getting-NEW-firmware-for-the-Nighthawk-M1. I think the version I've got is later than yours - its build date was in November. Hopefully you'll get an update soon. Sounds like you're going to have to keep the pressure on Telstra...
