Teewee4134
Apr 07, 2018Guide
Nighthawk M1 (MR1100)
I will like to compare and share my Nighthawk MR1100 Routers experience. Location Kuwait I owned two Unlock Nighthawk hotspot routers (MR100), one from Australia (Telstra) and USA (att). Both have ...
JasonN
Apr 10, 2018NETGEAR Employee Retired
Hi Teewee4134,
I just wanted to confirm that you had AT&T unlock your device.
Please let me know. :]
- Jason N
Teewee4134
Apr 10, 2018Guide
Yes Sir,
Att did unlock the (MR1100) device.
- JasonNApr 19, 2018NETGEAR Employee Retired
Hi Teewee4134,
Please contact support and they will be able to help you with the issue.Please let me know the outcome. :]
http://www.netgear.com/support/contact.aspx
- Jason N
- newbie3Jul 05, 2018AspirantI use this router in the Philippines.
With the ISP Smart it works out of the box, the remaining traffic is displayed and the speed goes up to 50 Mbit which is good.
However, with Globe it doesn't work. On the control panel it also doesn't show a service number. No connection can be established. I tried it with 3 different SIM cards.
Since I mainly bought this router because of Globe it makes it quite useless for me.
Is there any solution for this?- Blanca_OAug 05, 2018NETGEAR Employee Retired
Hi newbie3,
Did you configure APN settings for the said ISP?
Blanca
Community Team
