chefben
Mar 31, 2017Aspirant
NIGHTHAWK M1 Telstra Firmware ????
Bought this M1 device to replace the AirCard 810S, also known as Telstra Wi-Fi 4GX Advanced III and DC112A I bought the deivce because our landline sped is only 4mb and NBN is years away. I...
unlochka
Apr 22, 2017Aspirant
Hello.
I was also interested in the firmware for my device MR1100!
On my device the screen constantly saying "Detecting service" (see attached). Are there any other firmware? Ready to become a beta tester to test the networks of other operators in Russia.
Thank you.
PerthPhil
Apr 29, 2017Tutor
Had a Nighthawk M1 for a month after being advised by Telstra that this would make a good fallback whilst they fixed the firmware issues on their Gateway Pro / Netgear V7610.
Results were intermitant at best, only able to get link status 1 in five times and sometimes not at all despite however many times I patched / unpatched. I tried Cisco 887 router, desktop, forcing speed on NIC.
After 4-5 weeks of frustration, tech calls and a formal complaint, Telstra agreed to take it back and waive all charges.
It is a spectacular concept but ethernet justn't work and 4G performance is no better than aircard or MF910 until the base stations and backbone are upgraded (dependent on where you live)
Personally I suspect Telstra has diddled the firmware with a constraint so that it only works with a desktop (not switch) but that the restriction did not implement well. I have no inside information to support this theory by the way - just conspiracy :)
