Apollon
Mar 13, 2019Apprentice
Nighthawk M2 MR2100 features and availability
Does MR2100 have dynamic DNS support, sorely lacking in MR1100? I'm interested in using it as a primary home internet solution and want to know if the router supports inbound connections from outside...
Apollon
Mar 27, 2019Apprentice
If this supports dynamic DNS - it'd be the time to say goodbye to Netgear. You reap what you sow.
phillipmcmahon
May 03, 2019Guide
Just run a ddns client on your LAN. Dead simple.
Not quite sure why this one feature would be a show stopper. I assume all you want is a way to publish services and/or get back to your home network from an external network location which implies something is up and running and could happily host a ddns client in parallel. Problem solved unless I am missing something here.
