Apollon
Mar 13, 2019Apprentice
Nighthawk M2 MR2100 features and availability
Does MR2100 have dynamic DNS support, sorely lacking in MR1100? I'm interested in using it as a primary home internet solution and want to know if the router supports inbound connections from outside...
Apollon
May 06, 2019Apprentice
phillipmcmahon You are very confused about several things, such as the purpose of this thread and my need in your advice/ideas/suggestions, so let me be CRYSTAL CLEAR, as I take the time to clarify these things for you:
- The purpose of this thread (besides recieving product availability information directly from Netgear, and NOT user speculations about it) is to point out to Netgear essential features, currently missing from the device and communicate to Netgear the need to make those software enhancements in the upcoming firmware updates. Trying to come up with workarounds for the missing features goes directly against the purpose of this thread, as it may create false impression for Netgear product managers that implementing these features may not be all that important, if an easy workaround exists (for the record - it does not). Therefore, your efforts to provide any workarounds are counterproductive, as they undermine the very purpose this threat was created for, and they are unwelcome.
- I'm a principle level software and networking engineer (among other things), with over 20 years of experience in those areas. You are NOT qualified to give me advice on any workarounds, related to networking issues discussed here. I've done extensive, professional grade research on all these issues, and therefore I already know everything there is to know about possible solutions/workarounds for lack of dynamic DNS support, and I'm already doing about it everything I need to do. For the aforementioned reasons, your advices/ideas/suggestions on this topic are not needed or welcome.
- About 90% of what you said in your last lengthy post is a complete nonsense and is simply false. I won't spend my time refuting your statements one by one, but I will say this again: you are NOT qualified to give advice on these matters. Based on the things you said, you are trying to give advice on things you are clueless about, and as stated - no advice is required in the first place (even if you did suggest something that was correct).
I hope this clarifies where we stand on the need for your input on workarounds for lack of dynamic DNS support, and I hope we can get the conversation back on track and make it again about missing features Netgear needs to implement, and things like ETA for this product's release for North American market.
phillipmcmahon
May 07, 2019Guide
Rather than just posture about how right you are and how wrong I am, how about you share your information related to the easy workaround for CG-NAT and also how implementing a DDNS client on the Netgear would help.
You keep mentioning a lack of DDNS support, can you please explain what would be solved if you have either the CG-NAT external IP or the internally assigned IP that could only ever be supplied by the client?
As stated earlier whatever IP you get from a DDNS client is NOT going to be routable if you are behind CG-NAT. There are whole business models offering paid for solutions to help people solve this problem. I mentioned one already, ngrok. Essentially a proxy solution.
I don't disagree that a DDNS client could be useful in some situations. But the moment CG-NAT got mentioned then there is simply no way DDNS can help you here for the reasons in the paragraph above.
Your experience and roles sounds impressive... however you seem less than capable to discuss a topic that might require a back and forth. What of what I wrote earlier was incorrect to the tune of 90%?
Consider I have a CG-NAT setup, I have implemented a solution both using a vpn tunneling setup and also light weight proxying via ngrok that has allowed me to access my network remotely and publish persistent services via static links. None of this was possible using any form of DDNS client. I also know what I am talking about. If you still disagree rather than just say so, then SHARE what you know.
