MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
JohnPeng
Jun 20, 2023NETGEAR Expert
sbrady4 wrote:
I'm having similar problems with an AT&T M6 (MR6110) less than 1 week old. I'm using it without battery and ethernet only (wifi off) to feed my router. After various lengths of time (1 hour, 8 hours, 2hours) it drops out - the internet connection is dropped. Unplugging it and restarting it usually fixes it.
Please send me the model.json file to me at jopeng@netgear.com with your community name.
- Logon to the webui (http://192.168.1.1 ) as an administrator. Log in to WebUI first
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
DistillMill
Jun 20, 2023Aspirant
I'm having the same issue with mine. I've sent an email with my model.json data
- dmcshaw61Jun 23, 2023TutorI am also having these problems. I am using with no battery and in performance mode. I am getting lower speeds and pings the longer it is on. It randomly disconnects without losing signal. Resetting seam to help, but doesn't last long. Current version is NTGX65_12.01.16.00. Any help would be appreciated
- dmcshaw61Jun 23, 2023TutorModel number mr6110 from AT&T
- dmcshaw61Jun 23, 2023TutorMr Peng
I have sent you my json file
Thanks for your assistance
- sbrady4Jun 23, 2023Tutor
My firmware was NTGX65_10.01.47.00, so at least you have a more updated version.
- dmcshaw61Jun 23, 2023TutorYes, but it got worse with the new update!
