MikeG29
Mar 19, 2023Initiate
Nighthawk M6 Pro MR6500 Dropping internet
My Nighthawk M6 Pro MR6500 keeps disconnecting from the internet. It will show it has a signal on the device itself but my computer will have no connection. I only use the ethernet port, I don't use ...
jdrch
Apr 11, 2024Apprentice
> Please capture a model.json file and email me at [email protected].
I captured the file but ironically I'll have to email it to you later as the device the file is on is connected to the hotspot, which has no mobile broadband connection as a result of this exact problem đ It's amazing what limitations you run into when a nearly $1000 product literally does not work.
> For Verizon disconnection issue, most likely it is related to Verizon data plans.
I'm on the Verizon 5G Unlimited Plus hotspot plan on a postpaid account. I have an Inseego MiFi 5G UW on the same postpaid account with the same plan and it works just fine under the same conditions. Also, as the thread shows, users with across multiple carriers, including AT&T and Telstra, are having the same issue. So this has nothing to do with Verizon at all and everything to do with NETGEAR's product not actually working as claimed.
> I helped a few Verizon customers to resolve the issue.
I hope so. I also noticed that no one has replied to this thread that their problem has been resolved, so my expectations are low. However, I'm willing to try.
I should point out that the issue seems to occur only when Ethernet is connected. Which is absolutely terrible because the Ethernet port is main the differentiating feature of the product and the main reason I was willing to spend almost twice as much as I paid for the Inseego.
JohnPeng
Apr 11, 2024NETGEAR Expert
[John] This is the issue I am talking about Verizon data plan. Since your current SIM card is tied to Inseego MiFi 5G UW, you need to visit Verizon store to activate a new data plan with M6's IMEI. Moving the SIM card from Inseego MiFi 5G UW to M6 directly may not work.
We have confirmed that the following Verizon plans can be activated with M6's IMEI.
Post-Paid:
Pre-Paid:
You may also experience other data disconnection issue due to thermal mitigation. I can work with later after we resolve the Verizon data plan issue.
Thanks
- jdrchApr 11, 2024Apprentice
No, it isn't. As I said in my previous message, the Inseego MiFi is an additional hotspot on a separate plan on the same postpaid account. Because the both the Inseego and NETGEAR are on separate plans and I intend for them to be used simultaneously (in different locations) I have separate new, never used in any other device SIM card ordered directly from Verizon for the NETGEAR.
Thanks for the list of plans. Ironically the one it looks like the More Unlimited one is less expensive for me than the 5G Unlimited Plus plan I currently have.
I've upgraded the firmware and done the factory reset as advised, and have reconnected the device to the Ethernet client (a laptop). The connection drops are continuing. Error codes are:
Error - type #0, reason #0 (displayed when I tap Network Map)
Error - type #2, reason #211 (displayed on Mobile Broadband Disconnected popup)
I should also mention that I've been having the connection drop issue running in the Performance Power Mode (necessary for the Ethernet port to work).
What should I do next?
Update: I changed my plan to the More Unlimited as advised, with effective date today, then rebooted the hotspot after taking the battery out and pressing the power button for 30 seconds to zero everything.
It made things worse: now Network Map shows a constant â. No 5G connectivity at all. Tapping Network Map shows the following error code:
So yeah, I really don't think this is a Verizon problem at all.
Also the HW version is 1.0 <- maybe that's the problem?
- JohnPengApr 11, 2024NETGEAR Expert
jdrch I am not sure how you could switch your data plan so quickly. Verizon system is complicated. I would suggest you getting a new SIM and activate the plan with M6 IMEI. Verizon network requires SIM activation when you use the SIM card on a device for the first time. Then the SIM card and the device will be associated in their system. Simply assigning a new data plan on an old SIM card may not change the SIM association with the device.
I had 3 Verizon customers reached out to me with the same issue and the cause of the issue is the same that they used an existing Verizon SIM card on M6.
The SIM and the device association don't required by ATT and T-Mobile. So it is rare to see the same issue on ATT and T-Mobile if a customer gets the data plan from their BYOD portals.
Thanks
