DarthKoda
Feb 18, 2019Guide
Nighthawk MR1100 FW NTG9X50C_10.20.05.02 Wont Update
No matter what I do. I can't get my router to do a Firmware update. It's driving me crazy. I have to manually power off then on the router every 24 hrs. Why? Because after 24hrs, the router stops wor...
Bravo701
Oct 30, 2020Tutor
cgigate wrote:This is not solution.
It actually flashes the generic version firmware to the at&t device
That certainly IS the solution.
You lose Band 48 LAA...
and overheating
You GAIN:
Speed
Stability
Fully charging the battery
The ability to update
I use the MR1100 as primary internet very far from "civilization".
Converting the 2A1NAS to 100NAS, and dropping back to v12.05.05 has been wonderful.
I no longer have to flip-flop bandlocking, or even reboot the unit multiple times per day.
I can stream an entire movie without touching the hotspot.
I could not do that on AT&T firmware.
Mrblazed
Oct 31, 2020Star
Plus, you can find the At&t firmware online if you look hard enought...
