AJTheo
Dec 07, 2021Aspirant
Nighthawk R7100LG Disconnects Hourly
I have the R7100LG and have the following issue. ISSUE: The internet connection interrupts for 2 seconds then reconnects *every hour exactly*. As a result I am kicked from online services I have to...
Dec 07, 2021Guru - Experienced User
So your not near any other wifi and only using the SIM card.
Just wondering, if you turn OFF the wifi radios on the router and just connect wired PCs to the router, does the problem happen?
Any chance you have a nieghbor, friend or family member you could take the router to and connect it to there modem, Just to see if the problem follows? I'm wondering if this could be a 4G cell signal issue OR, if the router also does this when using the modem WAN port does it do it there as well. If it does it on both modes, possible that the router could be faulty. If the modem doesn't exhibit the problem with the modem port being used, possbile this could be 4G cell signal issue and the router using SIM.
AJTheo
Yeah, no other wifi networks in range of me. Just using the Vodafone SIM.
Checked turning off wifi and just using wired and the problem persits on my PC which is wired directly to the router.
I have tried the SIM in a mobile device both next to the router and at a friends and there was no problem for the full 4 hours I tested it. The router is showing full signal in the connection status window.
I have seen one post that suggests I may be something to do with lease expiry:
but to be honest I don't know enough about this stuff to know if that could be my issue.
AJ
