dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
MikkoFI
Jan 27, 2018Tutor
And I'm running latest firmware. I also tried to disconnect, connect the 4G but no luck, boot is the only way to solve the problem until it disconnects again.
Firmware Version
V1.0.0.38_1.0.6
dam_ged
Jan 27, 2018Guide
ElaineM JamesGL ???
Help!!! R7100LG users need follow-up !!!
The link to beta FW doesn't work anymore. Was it withdrawn since it does not contain the lastest security patches??? http://files.netgear-support.com/go/?a=d&i=2AD3JlvTm8
- dam_gedJan 28, 2018Guidegamoul
How did you monitor tcp/udp disconnects...?
The only way I have to show see precisely when it drop is to virtual connect to my office desktop via Citrix which freezes upon internet drop out.
Do you have any command line that would help document frequency of dropouts? Thanks- gamoulJan 28, 2018Aspirant
I have a permanent IRC connexion that get disconnected every hour.
I also do support with TeamViewer and I get a freeze.
Also if I play online there is a lag for about 10-15s.
But if I leave a ping running, no timeout.- slaskawiJan 29, 2018Tutor
gamoul That's exactly what I was about to suggest. Using IRC (I confirmed this using Konversation and XChat) is the easiest way to reproduce this issue. Just turn it on, sit and wait.
I also ran `ping` and `curl` in a loop to see if this happens also to the new connections. The answer is negative. Pings and curl queries were all successful. Only the established TCP connections are dropped.
Come on Netgear! Now, there is no excuse, you can reproduce it in your own lab!
