dam_ged
Sep 18, 2017Guide
R7100LG Internet via LTE drops out every hour precisely (interrupts video conf calls, games, stream)
Hello,
I have been using the R7100LG for several months without any noticeable issue until I started using video conferencing (Skype for business, formerly Microsoft Lync) on a regular basis le...
- Jul 15, 2018
Hi gbuisson,
Do you have the updated firmware (1.0.0.46) installed?
Blanca
Community Team
TowerStudio
Jan 31, 2018Tutor
Ok this is really weird. As I started unpacking the modem, I removed the three antennas and, wondering if the reception was any good without them, I ran some speed test. Then I had other things to do and left everything like this. It's been over an hour and a half and I didn't have any disconnection yet. Guys can you try if it does the same for you? Maybe I'm totally wrong and I missed the disconnection but I've been using the computer since and as I have the modem reset around a fixed round hour so I know when it will disconnect, it should have disconnected 10 minutes ago and definitely didn't... I'll keep an eye open, let me know if that does anything to you.
