What44's avatar
What44
Follower
Oct 25, 2018
Re: Router Keeps Rebooting
My hotspot reboots every 30 seconds when I use it at home, in town.
But at a vacation home in a more remote area, it works fine, all the time.
Is there anythng about a crowded cell tower, or the presence of several other wifi signals, that could cause the inexplicable rebooting?
I'm using: AT&T Hotspot Netgear Aircard 781S
    • JSchnee21's avatar
      JSchnee21
      Virtuoso
      I used to have this problem with my MR1100 where certain towers would trigger a reboot -- especially under heay load.  But haven't had this issue in a while (two firmwares ago).
      I suggest trying a hard reset.  Check for a firmware update through the web admin page.  And if there is one, after it is fully applied, do another hard reset.
      Disable dual band Wifi -- choose only 5.8Ghz if possible, 40Mhz, Long.  If not, then 2.4Ghz, 20Mhz, Long.  And keep the unit plugged in with a quality QC2/3 charger (Anker) whenever possible.
