lund33
Feb 23, 2018Follower
WAC120 DETAILED installation help for newb
I am about ready to put this thing in a vice and burn it. I do not understand anything that is not plug and play. I have had this thing for almost a year and I cannot for the life of me figure out ho...
Juliwade01
May 16, 2018Aspirant
I tried the factory reset. Had to also turn off/On before WiFi would begin broadcasting again. I now (still) have an access point that my devices can see but fail to access up address, with the added bonus that I am now no longer password protected, so will have to reset that if I ever get things working again. So no unfortunately it has not solved the problem. Sorry if this sounds sarcastic but getting a bit fed up, especially as this is a replacement wac120 only got it from Netgear in Dec 2017.
JasonN
May 30, 2018NETGEAR Employee Retired
Hi Juliwade01,
Can you please explain your physical set up so it can further help me with finding a solution? Thank you. :]
- Jason Nguyen
- Juliwade01May 30, 2018AspirantHi Jason Nguyen
I have a virgin media hub 3.0 connected via ethernet cable to an online plug on my ground floor, 2 floors up I have the wac120 connected via Ethernet cable to the pair of the plug and have used this to enable WiFi in my attic bedroom.
Julie
