DaForc3
Jul 01, 2017Follower
When are we getting NEW firmware for the Nighthawk M1?
The M1 is currently suffering from... Wireless stops responding Random reboots Battery sometimes refuses to charge Ethernet going to sleep Constant issues with usage meter Poor upload perfor...
- Nov 14, 2017
Hi Wiz_THS,
The current implementation on 10.16.04.04 (MR1) is as follows:
- MR1100 boots up and ethernet port is live for about 30 seconds
- If Ethernet port detects something plugged in it will remain active
- If Ethernet port detects nothing is plugged in it will disable the port to preserve battery life
We are investigating ways of keeping the ethernet port active whilst still trying to preserve battery life. These fixes could possibly be implemented in MR2 but not commited as yet.
Kind Regards,
ArodiD
MicW
Aug 10, 2017Luminary
As an afterthought. This modem does seem to be designed for the use you have it set up for. It has a data offloading which means it will use data from another modem eg:ADSL landline before it uses 4G. Have you tried using that feature? Settings>data offloading . You can connect to the other modem via wifi or ethernet.That may solve your issue by keeping it awake.
Just a thought
Wiz_THS
Aug 17, 2017Aspirant
Tried doing a factory reset but it didn't help.
I don't really want to go down the patch of data offloading.
Is it really that hard to make a firmware update so keep the ethernet port always active?
- MicWAug 17, 2017Luminary
yeah, drop down box option in settings for always on or sleep after x minutes would be nice. Is it possible to configure your router not to have its port in standby. If the M1 see's its port is terminated it will stay awake. Mine has never gone to sleep even with no traffic on the network , as long as it has an active termination
- Wiz_THSAug 22, 2017Aspirant
Unfortunately not, it's configured with an active/standby mode where the main link is active and the 4G is standby. Should the main link fail, the 4G changes to active. Issue is that the Netgear M1 is no longer active and it doesn't fail over. We have used other Netgear 4G devices in the past without issue. This is the first Netgear 4G device we have used with such an annoying issue.
- ArodiDNov 14, 2017NETGEAR Expert
Hi Wiz_THS,
Kind Regards,
ArodiD
