Fiddlin
Mar 16, 2022Tutor
Read status of LM1200
Does anyone know of a way to read the status of an LM1200 without watching the web page? I would like to use anything similar to SNMP to just get a text reading of connection status, cell signal lev...
- Mar 17, 2022
You can try to log in to WebUI as admin and capture the model.json log. It will present the info you require. If you need any help on reading the logs, I can help.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backHope this helps.
Thanks
JohnPeng
Mar 17, 2022NETGEAR Expert
Hope this helps.
Thanks
Fiddlin
Mar 18, 2022Tutor
Thanks John! There is a ton of data in there. That should work great for building a small status display app.
- FiddlinMar 18, 2022Tutor
Well, the data is in there, but so far, I have not figured out how to get the full (logged in version) model.json data with a script rather than just getting it with a browser. Do you have any suggestions?
- JohnPengMar 19, 2022NETGEAR Expert
I am not a programmer, but can you check the following link to see whether this is helpful?
https://stackoverflow.com/questions/34393353/login-to-a-website-using-script
You can run one script to get the model.json periodically and run another one to parse the data you need.
Thanks
- FiddlinMar 20, 2022Tutor
I did finally get it working. I was hoping to just use javascript in a local HTML file, but I ran into a ton of CORS (cross-origin request) errors. I got it working by using PHP and its cURL library. It is nice being able to see my GB/day remaining so I can maintain my data-rationing.
Thank you for the help.
