LauraArm54
Mar 27, 2021Tutor
Rebooting of Nighthawk MR5100, wifi signal strength loss, alternating between 4G and 5G
I have a few issues with my Nighthawk MR5100. Where I placed my wifi in my room, after I bought it, a month ago, it showed 5 bars with excellent signal strength at 5G and fast download speeds. It...
- Apr 14, 2021
Hi Bianca
Thanks for your reply
The SKU is SKU:MR5100-1TLAUS
My Internet provider is Telstra in Australia.
The firmware is NTGX55_10.29.07.00
I reset it to factory settings once a week and reboot it daily, and no change.
My internet provider said that the tower close to me could have shut off 5G and is doing maintenance...but that was a month ago?
I only get fair to good signal strength, 5G in the one spot...the other areas apoor to fair with 4G
It has rebooted on its own a few times. My room is not hot
Cheers!
Blanca_O
Apr 14, 2021NETGEAR Employee Retired
Hi LauraArm54
Welcome to NETGEAR Community!
May we please know the device SKU (MR5100-xxxx) and firmware version?
Who is your Internet provider?
Have you tried factory resetting the device?
Blanca
Community Team
LauraArm54
Apr 14, 2021Tutor
Hi Bianca
Cheers!
- ArodiDApr 15, 2021NETGEAR Expert
Hi LauraArm54
Can you please send me your IMEI? It should be on the device label when you remove the battery.
Arodi
- LauraArm54Apr 15, 2021Tutor
Hello!
My the IMEI is 358739540039170
Cheers
ArodiD wrote:Hi LauraArm54
Arodi
- LauraArm54Apr 18, 2021Tutor
Thank you to the netgear on line help support, and to Arodi!!!!!
Problem solved! I was provided an update and now I get excellent signals in all places in different places in my room.
Previously, my device kept stating that my firmware was up to date everyday when I checked for updates everyday!
Thanks again!
