croooow
Jul 11, 2023Guide
Rebroadcast Changing WiFi sources
So, moving from RV camp to RV camp, and then back home again, I would like to have a stable router with WiFi settings (currently using an R6700) to light up all my devices, while having a simple mean...
michaelkenward
Jul 12, 2023Guru - Experienced User
That's an interesting challenge. If you want to use a standard router set up, then you might not be in the best place to seek help.
This section is for Cell Service Mobile Hotspot Modems, AirCards, & Mobile Routers. That might be a good alternative, but it uses the cellphone network rather than local wifi sources.
You could also try:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
That's a step up from the devices you picked.
