jprobins007
Feb 18, 2025Tutor
Reccomendations Sought for Cellular Modem (standalone or bridge mode available)
I am planning on adding failover and load balancing to my networking setup. I am using a Nighthawk RS700 as the router and a TPLink 707 as a bridge solely for its failover and load balancing features...
rcpax
Feb 18, 2025Luminary
the 150mbps is the throughput of what? LTE modem (WWAN) or LAN? for t-mobile I can recommend the MR6550 or MR6150. You can do IP Passthrough which is the closest you can get to a bridge mode on these devices. LAN speeds on these devices can go up to 2.5gbps.
jprobins007
Feb 18, 2025Tutor
RCPAX: I guess I was speaking very generally. The material on the LM1200 states it supports "internet speeds up to 150Mbps". I am guessing that limitation derives from it being 4G instead of 5G.
- rcpaxFeb 18, 2025Luminarysounds like you’re looking for better speeds. of course for mobile internet that would be very dependent on location. but the MR6150 woild be the cheaper option of the 2 and it is 5G capable. plenty of bandwidth when used with tmobile.
