HDcustom's avatar
HDcustom
Follower
Sep 07, 2020
Recommendations For Remote Location Streaming
I have a cabin a remote area of Northeast Michigan and have no power.  The entire cabin is run off an inverter system.  I have a new ROKU TV and would like to watch TV + stream movies (Netflix, Amazon, etc.) at the cabin and trying to determine the best way to connect to the ROKU since I do not internet service.
I have good cell phone coverage at the cabin (Verizon) and trying to determine if I am in need of purchasing a cellular / portable router or if I need a USB cellular modem and then a wi-fi router???
Any insight, suggestions, previous success stories, etc. would be very much welcomed and appreciated!
Thank you...
1 Reply
  • I'd first check to see if you have enough speed. Most phones can act as a hot spot. I'd try that out first to see if the speed is fast enough for video streaming. It'd be pointless to buy a hotspot or router with integrated sim card if they couldn't provide fast enough speeds to be worth it.
