stopper9327
Feb 03, 2021Guide
red light
Hi All Help needed my Mr2100, as a red flashing light showing no wifi signal so can't connect. Sid is ticked but not broadcasting the wifi, works via ethernet, light flashes blue but when unplug...
Blanca_O
Feb 05, 2021NETGEAR Employee Retired
Hi stopper9327
Welcome to NETGEAR Community!
Please check if Wi-Fi Standby option is set to Disabled.
May we please know the device SKU (e.g. MR2100-100NAS)? This can be checked on the box of the product or on the barcode label
What is the firmware version?
Blanca
Community Team
- stopper9327Feb 06, 2021Guide
Hi Blanca
Thanks for replying, I can confirmed that the wifi stanby is set to disabled, mt sku is : SKU:MR2100-1EEEUS, I have a EE data sim
for the device which was working perfectly until now. The firmware is NTGX24_10.13.09.00 do you think my firmware could be corrupted?
regards
stopper9327
- Blanca_OFeb 07, 2021NETGEAR Employee Retired
Hi stopper9327
Were you able to check if there is a new firmware update available?
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Blanca
Community Team
- stopper9327Feb 08, 2021Guide
Hi Blanca
I can confirm that I have checked for a firmware update, and I have tried some of the forums solutions i.e data offloading trick with no success. Also done factory reset a few times and still the same results red X near wifi, not correcting it.
regards
stopper9327
- Blanca_OFeb 10, 2021NETGEAR Employee Retired
Hi Matty_K85
Please provide the device SKU (e.g. MR2100-1EEEUS) and firmware version.
Blanca
Community Team
- Matty_K85Feb 10, 2021Tutor
Hi Blanca,
Thank you, here are the requested details:
SKU: MR2100-1TLAUS
Firmware: NTGX24_10.17.10.00
Cheers,
Matt
