stopper9327
Feb 03, 2021Guide
red light
Hi All Help needed my Mr2100, as a red flashing light showing no wifi signal so can't connect. Sid is ticked but not broadcasting the wifi, works via ethernet, light flashes blue but when unplug...
Blanca_O
Feb 05, 2021NETGEAR Employee Retired
Hi stopper9327
Welcome to NETGEAR Community!
Please check if Wi-Fi Standby option is set to Disabled.
May we please know the device SKU (e.g. MR2100-100NAS)? This can be checked on the box of the product or on the barcode label
What is the firmware version?
Blanca
Community Team
stopper9327
Feb 06, 2021Guide
Hi Blanca
Thanks for replying, I can confirmed that the wifi stanby is set to disabled, mt sku is : SKU:MR2100-1EEEUS, I have a EE data sim
for the device which was working perfectly until now. The firmware is NTGX24_10.13.09.00 do you think my firmware could be corrupted?
regards
stopper9327
- Blanca_OFeb 07, 2021NETGEAR Employee Retired
Hi stopper9327
Were you able to check if there is a new firmware update available?
Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
Blanca
Community Team
- stopper9327Feb 08, 2021Guide
Hi Blanca
I can confirm that I have checked for a firmware update, and I have tried some of the forums solutions i.e data offloading trick with no success. Also done factory reset a few times and still the same results red X near wifi, not correcting it.
regards
stopper9327
- Blanca_OFeb 08, 2021NETGEAR Employee Retired
