stopper9327
Feb 03, 2021Guide
red light
Hi All Help needed my Mr2100, as a red flashing light showing no wifi signal so can't connect. Sid is ticked but not broadcasting the wifi, works via ethernet, light flashes blue but when unplug...
Matty_K85
Feb 09, 2021Tutor
Hi guys,
Mine is doing exactly the same, was working fine until I did a firmware update and now no wifi and red flashing power button. Can also connect via USB.
Any updates? Is there a resolution or is this a hardware issue?
Cheers,
Matt
stopper9327
Feb 10, 2021Guide
Hi
Just to let you know that support is still looking at it, and are trying to resolve it, I will posted if it is fixed.
regards
stopper9327
- stopper9327Feb 10, 2021Guide
Hi all
Sopport was unable to resolve this sayingh it might be a hardware issue, so not resolved unfortunately.
suggested return to seller.
regards
stopper90327
