lpfleghardt
Jan 02, 2018Follower
Replacement Battery for Nighthawk M1 (MR1100)
Where can a Nighthawk M1 (MR1100) be purchased? I believe the mobile hotspot device takes a W-10 battery? Thanks in advance Model: MR1100|Nighthawk LTE Mobile Hotspot Router
pkdstuff
Feb 15, 2018Tutor
Nowhere on this forum or on additional Netgear and AT&T websites can I find information on how to get a replacement battery. So, does anyone know how a battery for the MR1100 might be aquired?
JasonN
Feb 15, 2018NETGEAR Employee Retired
Hi Ipfleghardt,
What provider do you have for your MR1100?
Hi pkdstuff,
If your MR1100 is AT&T then you can purchase a battery through AT&T. It will take around 3 months because I believe they are backlogged on the item. You can contact AT&T to confirm this.
- Jason N
