lpfleghardt
Jan 02, 2018Follower
Replacement Battery for Nighthawk M1 (MR1100)
Where can a Nighthawk M1 (MR1100) be purchased? I believe the mobile hotspot device takes a W-10 battery? Thanks in advance Model: MR1100|Nighthawk LTE Mobile Hotspot Router
Pgirl
Mar 16, 2018Aspirant
Have had problem with battery for nighthawk m1100. We have two devices. One works great! The other has had problems since the get go and turns out it is because if a defective battery. Att says they do not have any, that I would have to buy a whole new nighthawk unit with everything and have a 2year contract. If don’t want to do that to contact netgear to purchase battery. Netgear says to buy one on amazon or another 3rd party source because they do not sell to individuals. Cannot find one anywhere. Any suggestions?
- JasonNMar 16, 2018NETGEAR Employee Retired
Hi lpfleghardt & pgirl,
Pgirl is correct. We do not sell the battery individually and that a whole unit would need to be purchased.
Thank you for explaining that for us. :]
- Jason N
- JSchnee21Mar 16, 2018Virtuoso
Hello Pgirl,
How old is your MR1100? If the battery is defective should't they (either Netgear or AT&T) replace the entire hotspot then under the original MFG warranty?
That said, I have no idea how long the hardware warranty is on the MR1100 -- 90 days? 365 days? The whole produce line is less than a year old, it only came out on Telstra last Spring.
Are you sure the battery is defective and not the charger? The oem charger in the box (aka wall wart) seems to be pretty subpar. Most of us have replaced them with a quality QC2 or QC3 rapid charger.
Which carrier do you have Telstra or AT&T? Make sure you have the latest firmware as (if Telstra) as some of the early firmware versions had battery charging related issues.
-Jonathan
- MikeFl1Mar 21, 2018Aspirant
I too have a brand new MR1100 Nighthawk ATT Router that has been having battery charge issues. Currently, I am on the second Router with the exact same issue of a battery that I have to remove the SIMM from for a couple of hours to get it to charge to 100% and 6 hours later it is already at 28%. I just today updated the firmware. Another Router (#3) is currently enroute for warranty replacement of #2. Third Router in less than a month! I found in the MR1100 Manual that it is possible to Quick Charge the battery, so I replaced the original charger with a QC2 2.4A Charger and that still doesn't keep up, so I was hoping to find another OEM battery to be able to charge and swap every 24 hours or so. Dissapointing to find out that NetGear doesn't sell accessories or replacement parts. Fortunately, I found an external antenna on Amazon that is a NetGear accessory (Netgear 6000450 MIMO Antenna with 2 TS-9 Connectors) that has helped a little with signal strength. Unfortunately, the W-10a NetGear Battery is not available from ATT or Netgear. It's specs are 3.85V, 19.78Wh, Capacity 5040mAh.
- DragonheartFLAug 15, 2018Aspirant
If you look on ebay they offer M-10 replacement batteries for $19.00 but you'll need to be prepared to wait a lil bit because they ship from china.
