emdored
Apr 30, 2024Follower
Replacement battery for Nighthawk M5
I have a Nighthawk MR5200 modem, and I purchased a replacement battery from netgear. But when i insert the battery, the modem shows me that the battery is not regocnized... any ideas. I tried the Net...
Blanca_O
May 06, 2024NETGEAR Employee Retired
Hi emdored,
Kindly check KB link below to check which battery works with your NETGEAR Nighthawk M5
Which battery works with my NETGEAR mobile hotspot?
Blanca
Community Team
