rwvdk
Nov 20, 2021Follower
Request for firmware update Netgear MR5200; possibility to change default 192.168.1.1 and 24 hour
Request for changes, deviceNighthawk M5 (Netgear MR5200); - Option to change the default IP-number 192.168.1.1 - Option to choose 24-hour clocksetting instead of 12-hour clocksetting
michaelkenward
Nov 22, 2021Guru - Experienced User
Is there anything Orbi involved here? That's what this section is for.
Many questions, including this one, are pretty generic and apply to all routers. Not need to dash all over the place. But the fine details can vary.
So, if the answers here don't work out, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
These are very different creatures from anything Orbi.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
The manual may help you to make the change that CrimpOn suggests.
