zephyr99
Jun 19, 2021Aspirant
reusing mr1100 firmware update
i have a couple mr1100 units. and the 12.06.39 update is available. does someone know the method to use so that i can download it once? the auto firmware update does not seem to tell me where the fil...
michaelkenward
Jun 20, 2021Guru - Experienced User
antinode
Jun 20, 2021Guru
> Once is usually enough.
If you actually read the two posts, then you might notice that their
questions are different.
You may have done this already. I can't tell from your message.
