mclarke21
May 03, 2018Aspirant
Rogers Air Card 330U on Mac OS High Sierra
I upgraded to High Sierra on my Mac and now the Rogers Air Card 330U doesn't work anymore.
Wondering if anyone has this issue and knows a fix for it.
Thanks,
JasonN
May 14, 2018NETGEAR Employee Retired
Hi mclarke21,
Thank you for posting in the community. I wanted to find out a little more information on this. Can any other devices connect to the AC330U?
Is your firmware up-to-date with the most current version? Below is the support page for your device.
Please let me know. :]
https://www.netgear.com/support/product/aircard_330u_(rogers).aspx#download
- Jason N
mclarke21
May 21, 2018Aspirant
Hi Jason,
Thank you for your reponse. The device was working fine prior to updating to High Seirra. It also works on a Windows machine. I will double check the firmware version.
mclarke21
