thingamajig
Jun 05, 2021Tutor
roll back firmware update m2100
hi all, is there some way i or someone else can roll back the firmware to original version.my problem is the modem is now using lots of data since updated.i had this problem/fault 23 month...
michaelkenward
Jun 06, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but your mobile router is not like the bog standard router so you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads.
- thingamajigJun 06, 2021Tutor
thank you, i am happy for a mod to do that. i did search support for an earlier version of firmware download , but none for my model i could find
- michaelkenwardJun 06, 2021Guru - Experienced User
What did you search for?
There is no "m2100". (See your subject.)
sorry that is a typo , i searched for previous /prior versions of mr2100 firmware
