Thundercat's avatar
Thundercat
Initiate
Sep 28, 2020
Router as Access Point or Bridge
Hi, Looking for some help here with an older Netgear router. My main router is in the living room and all my devices connect to that. However the signal to my Ring door bell keeps saying poor wifi c...
  • plemans's avatar
    Sep 28, 2020
    In access point mode, it needs to be hardwired in.
    You're trying to set it up in repeater mode/extender mode.
    It doesn't have that mode. You'd be better off to purchase a cheap extender that's designed to run that function. it'll work better, be more stable, and have better performance than the WGT624 (released in 2005, orginally in 2003).
    Its time to upgrade/discard that device.
