Mark_Spencer
Mar 14, 2021Aspirant
Router has never allowed me to connect directly to the Internet
Although the Nighthawk M2 seems to be a personal Internet connection device, I have never been able to achieve this. My primary use has been to boost/bypass my ADSL router, and provide throughput fo...
michaelkenward
Mar 15, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
These are specialist kit that doesn't share a lot of controls and features with standard Nighthawk WiFi Routers, hence its own bolt hole.
Mark_Spencer
Mar 15, 2021Aspirant
Thanks for that, I will try and reform this as it is an interesting issue.
