Dvi208's avatar
Dvi208
Follower
Feb 16, 2020
Router not showing Tmobile network in US
Hi, I bought the router in AMSTERDAM with A Tmobile data only SIM card, including 20 GB data in USA. To be able to use this I need to manually select the Tmobile network. However the router never shows the Tmobile network, regardless where I am. New York, now in Boston. There is a Tmobile network here but it does not show it to select. What to do? Thank you, Dayanara
1 Reply
  • some Telecom companies are banning their LTE bands of the routers , in your case it seems that your carrier banned Netgear routers .
