GAMBIRASIO
Oct 12, 2024Follower
routeur bloqué
comment obtenir le code puk de ma carte sim bloqué? merci de votre réponse
rcpax
Oct 12, 2024Luminary
GAMBIRASIO wrote:comment obtenir le code puk de ma carte sim bloqué? merci de votre réponse
hello. firstly, this is an English forum, so English is the medium we are expected to use here. But if I understand it right, you are looking for a way to retrieve your PUK for your SIM card. When you first bought your SIM card, the full sized card (1FF-size of a credit card), there should be printed the PUK code associated with the SIM. If for some reason your SIM came as a 2FF, 3FF or nano SIM (4FF), or eSIM, and there is no PUK given, usually your carrier will have that information. But granting that SIM was blocked, that might be a problem, and the carrier will probably refuse to give you that PUK unless you have settled whatever issue has caused for your SIM to be blocked in the first place.
