Moneybox
Dec 01, 2022Aspirant
Running the Nighthawk MR6110 on AC power
I've removed the battery after powering off. When I connect the USB cable the Nighthawk will not start. It shows a screen like it is looking for an Ethernet cable. I've done a factory reset and gone ...
JohnPeng
Mar 12, 2023NETGEAR Expert
Are you getting the image when you connect the USB cable to the PA provided with the device?
The image will show if you connect the USB cable to your laptop's USB port. Such connection is not supported since laptop USB port may not provide the enough power to operate the device.
Thanks
John
- MillsieMar 12, 2023Aspirant
Thanks!
