Msflyr's avatar
Msflyr
Follower
Jan 07, 2019
Rural WiFi Set up (M1 and Nighthawk ac1750)...Please help
Hello All...   I am new to all this, so bear with me.  I just moved to the country and have zero options for internet, so bought an MR1100 M1 for my home modem/router.  Last night I was able to g...
  • Mexoh1To7k's avatar
    Jan 10, 2019
    You want to increase the speed between the MR1100 and your router or the speed between the MR1100 and the mobile operator?
    If you use WiFi, you'll of course theoretically obtain highest throughput by using 5 GHz, 40 MHz bandwidth and a channel that's not too busy in the area.
